must check max pressure of the tires....
But there is another problem that here in Croatia, not only, also in Slovenia, Bosnia, Italy roads in the cities are bumpy, highways are perfectly flat!
With high tire pressure is not very comfortable to be in the car with bumpy road
Also in 90% cases i must park my vehicle on the sidewalk, that means that in 1 year i must climbe with 2 o 4 tires 300 times on the sidewalk high around 20 - 25cm ...
