T pins or AES Wave Pin Probes
do not poke a hole in the insulation , you will allow the green fuzzies to start forming inside of the harness and the wire will dissolve from the inside out
you will have a voltage drop that you will not know how to find
AES WAVE
sells probes , pin probes that will connect to leads for fluke and pico and other better quality test equipment .
like this connection to the signal pin of a Geo Metro Map Sensor
