Old 01-12-2011, 10:23 PM   #5 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
You could get temperature senders for measuring temperatures, but you'll have to calibrate your data logging equipment to work with these things.
You'll also want to rig up some sort of tachometer, driven inductively from the cylinder #1 spark plug wire. That'll give you engine speed.
Voltage is simple enough to directly record, but current is a little tricky. What sort of current are you measuring?
