Originally Posted by some_other_dave
I talked to an EE friend of mine about the taps. His opinion was that for something that is out of the weather in the interior of the car, a good-quality wire tap is a perfectly fine way of tapping into a signal wire.
I will admit that the thought of using them still doesn't make me very happy, though.
-soD
Good advice. I also heard it from an EE friend of mine, and he was correct. Anything that is in the outdoor elements of weather (read: under the hood) needs waterproofing; most interior applications don't.
I don't like crimp connectors for use in wire joining either. Between possible loosening and potential for corrosion, I avoid using them.
