Old 01-14-2011, 11:37 AM   #2 (permalink)
Daox
The scangauge should work just fine for you. You should be able to dial it in within a couple percent. Lots of people here use engine on and engine off coasting and the SG monitors both pretty well. The only thing the SG isn't very good with is diesels and lean burn engines. Even then, if you drive consistent and your commute is consistent I'd think the SG would be able to be dialed in pretty well.
