hey carwhat just my two cents but fordman is giving you the best direction on fixing your problem you can also ohm test an o2 sensor but if its oil coated you need to pull it out and clean it or replace it you will need probable need a special wrench to remove it you can borrow from autozone and i believe advance auto dont through parts at it find the problem first (usually)
