Old 01-17-2011, 02:26 AM   #3 (permalink)
star_deceiver
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
Did you disconnect the battery when you swapped mufflers? You've changed the airflow through the system, so you need to reset the ECU and let the computer relearn!
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
