Old 01-17-2011, 01:42 AM   #15 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Here's my version of an adjustable grille block. Hope it provides some food for thought.
Basically, two solenoids pull the 3 flaps to create an opening, hence providing sufficient cooling to the radiator. The sidewalls are there to provide an improved cooling efficiency.
I would like the flaps to be more distant from the opening, but most solenoids only have a reach of 1 inch or so. A linear actuator is a possibility, but its cost makes it a bit prohibitive for now.
Still haven't decided if the system will be automatic based on coolant temperature or fully manual. This is simply a basic conceptual drawing.
Any thoughts and/or suggestions ?
