Thread: New Prius C
Old 01-18-2011, 11:42 AM   #44 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
It is always risky to try and analyze a car from the images but one technique is to scale and combine images to see if we can gain insights otherwise missing. In this approach, I use the tire size and sideboard height as the 'known' units to scale the images between the Prius c and existing 2010 Prius, ZVW30:
This image suggests the "Prius c" is moving towards the Honda Civic or even CRX sized vehicle. It might make more sense to go two-door with a weight savings and improved access. The rear seats being more for small children, dogs, or mostly folded down to make more cargo space.
This shows the "Prius v" and ZVW30:
Now to compare the "Prius v" and "Prius c":
I see the "Prius c" as competition for the compact cars: Jetta, Minicooper and Civic. If the scales are right, it may come in at ~2,500 pounds and I would expect and advanced technology, 1.3-1.4 L engine . . . if Toyota has one in the works. I would also expect to see the inverter and A/C compressor being located outside of the engine compartment . . . say under the driver and passenger seats.
Of course this is all harmless fun and speculation. Folks with more time might make a tracing of each body style and achieve a better view. The size of the "Prius c" driver door does seem too small to support North American bodies.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following 4 Users Say Thank You to bwilson4web For This Useful Post:
cfg83 (01-18-2011), euromodder (01-18-2011), IamIan (11-15-2011), NeilBlanchard (01-18-2011)
