Old 01-18-2011, 11:26 PM   #4 (permalink)
Farlander
Water Fuel Designer
Thanks for all the advice!
I do have access to a shop (where I work as the assistant manager) however the availability of an open bay is scarce. I am however very knowledgeable and equipped with the tools to do almost any job, including an alignment rack. The car currently has lowering springs which are majorly annoying because it rides like hell. The control arms are all swapped out so to go back to stock suspension I really need the coilovers and control arms, added all up buying a good shell might make sense.
Does anybody know what the compression should be in each cylinder on the vx model? I will probably test that soon...
As far as the lights, not the overhead light nor any of the lights on the dash/gauge cluster are working. There are also some ghetto rigged fog lights which do not work either. The SRS and CE light however shine brightly....
Has anybody had any experience with doors not opening or windows falling down?
