Wow, thanks for the review!!
I am working on a new version, well, a respin, I will try to use surface mount component
and design an enclosure for it
EDIT: about the problem when it's below 0°C, I can see in my code that if the intake temp is negative it skips it thinking it's a timeout or a fault, I'll correct it and send you a new chip.
