Old 01-19-2011, 02:33 PM   #7 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by brucey View Post
4 degrees is what the number is around here for the bottom.
That depends on the chassis shape: A fastback or sedan has lowest aerodrag (Cx) around 3°-4°, but a squareback (like the Fiat Idea you used as an example) is better off with a flat rear(*).
(*) If the car already has a Kammback, then it is no longer a typical squareback and a slight diffuser angle may be OK.
On the other hand, race and performance cars have more aerodrag Cx and less Cz (= more downforce) when the diffuser angle is greater than 5°.
Either way, getting rid of, or covering up, a spare that hangs down in the air flow is something to think seriously about.
The Following 2 Users Say Thank You to Piwoslaw For This Useful Post:
brucey (01-19-2011), COcyclist (01-19-2011)
