Old 01-19-2011, 10:29 PM   #2 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
You need to use a strap wrench to keep your water pump pulley from moving, then use a large crescent wrench on the nut holding the mechanical fan to your water pump pulley. It actually comes off pretty easily, and no re-routing of serpentine belts is necessary.
Your electric fan comes on at about 210 F, assuming that Chrysler programmed your engine computer with the same setting as mine.
The Following User Says Thank You to t vago For This Useful Post:
morpheous71 (01-19-2011)
