Good work for the squeaking get some foam tape and attach it to the tail and see if that helps. For the snow sticking on the back attach a short lip at the bottom edge of the tail about 1-3" out from the current ending point and possibly make terminate an inch or so from the corners. You can then adjust till you get it how you like it or remove it, if it does not help.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
