Thread: 6 Stroke Engine
Old 01-22-2011, 03:20 AM   #1 (permalink)
c0re
6 Stroke Engine
I've recently become interested in the idea of injecting water into an engine in order to improve efficiency.
The 6 stroke engine cycle is effectively a 4 cycle engine with 2 added strokes: water injection and an steam exhaust stroke. The theory is of course that the water is converted to steam in endothermic process that will create an increase in pressure. This would have three effects:
  1. Turning waste heat from the Otto cycle used in a 4 cycle engine into useful work, thus substantially increasing efficiency
  2. Increasing peak power output of an engine due to there being 2 power strokes of six rather than one power stroke of 4
  3. Eliminating the need for a cooling system
Now I'd say that designing and building a 6 stroke engine would certainly be beyond the scope of what an average person can do as whole new cams need to be designed, high pressure water injection systems must be installed in the head and the ECM software would need to be completely revamped.
That said, what do you guys think about this cycle? It seems to me that it would be a very impressive way to recover a large portion of energy that otherwise gets wasted in the Otto cycle and tossed out through the radiator. Don't forget that most engines are around 20% efficient so most of the difference is tossed.
