Old 01-22-2011, 08:37 AM   #9 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Look at it this way.
If you want to lower the roof line and still accommodate the same height passengers, then you have to tilt them - and that results in a longer chasiss, longer doors and a longer roof - all of which add weight - and more weight than would be saved by using a lower roof.
And as we all know, reducing weight probably has the largest effect on fuel economy.
