T Vargo, tweek the sides of your V2 cap, you have fallen into the trap of creating a sudden change in air direction right behind the cab on the sides....do you see it? Just copy the line you have for the top (when viewed from the side) and put that line on the sides too, if looked at it from the top, otherwise, the top profile is GREAT. Keep up the good work. I like the flat area above the tailgate.
