I'm getting a barrier that's reflective on both sides which will help in the winter by reflecting the heat back into the house and in the summer by reflecting heat away.
I've thought about installing a radiant barrier but couldn't decide which way to put it.... Cold winters here! So both sides reflect kinda makes sense but... Why use it at all then? In the winter I'd want any heat to get down but in the summer I'd want the opposite. I suppose if it works off the temperature differential that could still work but is that how radiant heat works?
