Old 01-23-2011, 09:36 PM   #11 (permalink)
star_deceiver
KLR650 - '10 Kawasaki KLR650
6.4 - '19 Ram 3500
All Black - '19 Kawasaki Vulcan S
Coasting downhill in 5th gear @ 90km/h nets me about 125ish mpg. Coasting down the same hill in neutral at 90km/h gets me about 200+mpg according to the ecometer. I don't doubt that the results are quite similar when coasting/decelerating to a stop at a red light. This is from the 2ZR-FE 1.8L w/5spd stick common to the 09+ Vibe/Corolla/Matrix/XD.
The benifit of coasting in neutral is saving the clutch, which many can attest to, is a lot more expensive then replacing your brake pads!!!
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
