Originally Posted by mnmarcus
I've thought about installing a radiant barrier but couldn't decide which way to put it.... Cold winters here! So both sides reflect kinda makes sense but... Why use it at all then? In the winter I'd want any heat to get down but in the summer I'd want the opposite. I suppose if it works off the temperature differential that could still work but is that how radiant heat works?
Sorry I forgot to include the link in the previous post
Texas Heat Management — Store Home
The barrier will work in the summer and winter, because radiant heat always transfers from the hot environment to the colder, so the double sided reflective barrier reflects your heat back into your house and the cold away in the winter keeping it warmer instead of letting it go through the roof and in the summer it reflects the heat away from the house and reflects the cool air back into the house keeping it cooler.
