Old 01-24-2011, 02:30 AM   #10 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by groar View Post
To glide when I'm at "max speed" :
  • I push down the clutch,
  • tap on the brake to flash the brake lights,
  • keep my right foot over the brake and
  • switch off the engine.
Why do you tap the brakes? Is it to signal to other drivers that you may be slowing down? Maybe you should have a button to manually turn the brake lights on when EOCing or engine braking, so you don't have to tap the brakes?
I got the idea to plug a voltmeter at the 12V plug and found that its voltage was going under 10V In fact my engine switches on the heat plugs at each FAS and at each bump start during at least 8 seconds. After tens of P&G, the lights and the cabin fan to get a little bit of heat this is a lot of juice for an old 50Ah lead battery...
What you need is a switch to manually turn the glow plugs off! Maybe it could be integrated with the FAS switch? Or actuated by a coolant temperature sensor so that the glow plugs work only when the engine is cold?
