Old 01-24-2011, 08:14 AM   #19 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by jakobnev View Post
On my gasser the injectors have a common +12v-line and all their separate ground wires go to the ECU that connects each wire to ground when it wants fuel to be injected through that injector. If your injectors have a similar setup, you could kill the engine by simply interrupting the common +12v-line.
In certain engines (HDi's for example) both leads of each injector go to the ECU. This is because the injectors double as induction coils for increasing voltage to the required 50V-80V.
