I think the profile is a fine 2D guide, but is 3D, the air can flow in from the sides so the taper can be steeper *if* the sides are also tapered?
It's been mentioned before that you can get away with a steeper angle if the sides also taper in smoothly.
The streamlining template used is only 2D - the ideal low speed aero shape is an ice-cream cone (with only one ball of ice-cream
) where there are no
sides, only taper.
