Old 01-25-2011, 05:57 PM   #4 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by munky000527 View Post
I'm looking at getting the most affordable (least expensive) LRR tires recommended, but I have questions about the size that I should be looking for. My factory tires are 205/55/16" and I'm confused about how tires with a different size would still fit on my stock rims.
Only a few regular sizes will fit your rims and still keep the diameter within reason of the original diameter.
Adding LRR to the requirement will make the search even tougher.
You can get the Michelin Energy Saver in 195/60/16 , which is a close match, with a 1.4 % larger circumference - which is good for fuel efficiency, as it means 1.4% lower revs when cruising.
(It's one of the approved sizes for my car, along with 205/55/16.)
Over here the price for that tyre is a whopping 50% higher than the same tyre in 205/55/16 though - which isn't cheap to start with.
Though not the cheapest, the Energy Saver is among the best LRR tyres - especially when you look at fuel consumption and wear.
Goodyear's Efficientgrip and Optigrip also get good marks for RR and are available in 205/55/16.
Pirelli Cinturato P7 (not the old P7) also gets good marks for LRR and wear (somewhat unusual for a Pirelli).
