Old 01-26-2011, 07:35 PM   #1 (permalink)
Farlander
Water Fuel Designer
FS -'94 Civic VX
Hi All,
For sale is a 1994 Civic VX, painted flat black, NO RUST ANYWHERE, original motor and transmission, original computer and firewall controller, original interior, 177k miles, starts and runs fine, no smoke, no knocks or ticks, no burning oil, no leaks, no grinds or pop outs in the transmission, clutch is strong, car starts every time. Car is lowered, has 14" steel wheels with 175/65R14 tires, yellow fog lights, and a magnaflow muffler.
THE GOOD:
New Battery
New Radiator
New Axle(s)
New control arms
Original drive train and computer
NO RUST
THE BAD:
Car needs a windshield and the passenger side weather stripping
Needs 2 rear tires, could use all 4
Needs alignment and possibly tie rods
Driver door does not open
Passenger window does not work
Check Engine light is on, Code 48, Air/Fuel sensor (o2 sensor)
SRS light is on
Tail lights not working (brake lights, turn signals, headlights all fine)
Carpet is pulled back in some places
Console is perfect except for a hole in the far left vent
Heat does not work very well
I drove this car 211 miles to get it home with no problems and I averaged about 40 mpg, even with the check engine light and 2 VERY low front tires (about 13 psi). I was in love at first sight, my dream car had finally revealed itself on craigslist, and I'm still unsure I want to part with it, but if there are any serious buyers I will consider... Asking $1500
