Thread: Newb 91 CRX HF
Old 01-26-2011, 11:43 PM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The civic HX, 4 bolt civic hybrid (first generation) and Honda Insight rims are all pretty decent 14" rims, the civic HF rims are not only narrower but lighter weight compared to other steel rims, the VX rims I think are the only common alloy rims that will be a direct fit, 155/80R13 tires are not avalible as low rolling resistance tires, 175/70R13 are and there is debate but it seems like it is worth going with a wider LRR tire over an unknown narrower tire, of course some of that can be made up if you can get a higher max side wall pressure, of course if you go over that side wall pressure you are doing so at your own risk.
