01-27-2011, 12:00 PM
#22 (permalink)
Originally Posted by JacobAziza
Some of that is surely minimum maintenance fees and taxes, but did you look at the wheel on the meter and make sure it is perfectly still? There could be tiny loads somewhere you aren't aware of, perhaps something as small as inductive current in crossed lines. If it moves at all, try shutting off all the circuit breakers.
The bill shows 0kw used.
