Originally Posted by Frank Lee
I think you need to get the edge of the disc seated into the lip on the edge of the rim otherwise the disc will get a lil off-center then centrifugal force takes over and strains everything.
Also I have a suspicion that the zip ties are being forced to bend sharply (more than 90 degrees, and with very small radius) around sharp holes in the rims. You might want to come up with a new strategy, or put a backing of some sort on there to make those bends gentle.
The small radius may not have been a factor because the way I had them strung together allowed most of the turns to be made at the joint of 2 ties. Also With the big ones I put on today they definitely have to make the turns though. Backing's not a bad idea, I could probably put a layer or two of electrical tape on the part of the tie that goes behind the rim and back.
I think for now I'll just install the bigger ties and see what happens. Oh and cut another disc out to replace the burned up one of course
