Old 01-28-2011, 05:56 AM   #3 (permalink)
rfdesigner
Merc Estate - '01 Merc W210 E320CDi Estate Elegance
90 day: 37.56 mpg (US)
Originally Posted by polaris9898 View Post
I have an 06 jetta tdi. I have increased the tire pressure in my car. The car is out of warranty now and I'm trying to understand a few things.
I was trying to find out if I went to larger intercooler if that would help mpg and the pep the car has? The other thing is changing out the muffler to something that's more high flow. I read elsewhere that adding a fogger (water methanol solution has worked well with the older diesel vws. I read some place that he was able to get 3-4 mpg with the fogger on his 98.
As a diesel owner. may I suggest a some suitable easies.
I am UK based and therefore suffer the sub zero damp morning starts that kill fuel economy.
Therefore I can reccomend a grille block, it does three things for diesels.. it helps improve aerodynamic drag, it helps reduce the airflow over the engine which means improved warmup time, and a curious bonus I've discovered is that if you seal it in, it helps reduce heat loss when the car is parked. Thus the engine is a couple of C warmer in the morning. I strongly suggest blocking the UPPER part of the grille, not the lower part. It helps push air over the top of the car and helps in the parked insulation there... I've tried blocking upper and lower.. I've only had gains with the upper blocked. Do make sure you're not blocking off cooling to other components such as the gearbox
Tyre pressures you've done.
Mud flap removal bought me a couple of percent.
Weight reduction of course.
Adjust the nut behind the wheel.. let's assume you've done that.
Clean out the pipes.. diesels have dramatically higher air throughput that petrols.. if you've clogged pipes then that will hurt.. check your Mass Air Flow sensor and your Exhaust Gas Recirculation... which often get horribly coked up.
The exhaust will have diesel particulate filter (DPF) and/or catalytic converter, you MIGHT be able to delete these depending on local annual legal testing and what sort of control signals if any they chuck back... you might be able to chip the engine not to worry about the DPF.
Also take further a look around this site.. there are some excellent posts by someone else with a jetta.
Derek
