Old 01-28-2011, 08:17 AM   #4 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by polaris9898 View Post
I have an 06 jetta tdi. I have increased the tire pressure in my car. The car is out of warranty now and I'm trying to understand a few things.
Having a larger IC would be good, but the gains from replacing an existing intercooler with a larger one are much smaller than from adding one to a non-IC engine. IF you are going to do it anyway, then instead of replacing, plumb it parallel to the first - this will give you the best cooling and the biggest drop in pumping resistance, but still not worth it, neither price-wise, nor space-wise, nor weight-wise.
Improving your exhaust may give you better FE (Our Peugeot Diesel - Part 1 - The Exhaust), but then again it may not (New Muffler = Lost MPG's). A free flowing intake is good, as long as it's cheap and easy (1.9L VW/Audi/Skoda/SEAT Diesel Mod alert! )
And an upper grille block is a must if you are going to be driving a turbodiesel efficiently. In my case, the engine never really got up to temp, even with a lower grille block, until I covered the upper grille and put some thermal insulation on the engine.
