it can't stand on its own merits. its inefficient. but argue with logic not with intent to discredit.
no water is being injected into the engine. period. Hydrogen is being injected.
the fact that the result of this combustion is water is irrelevant.
My problem with HHO is not can it work but that it can not work efficiently and if you DO make a battery big enough to make HHO practical it will give you 3-6 times MORE RANGE if you just used it to run an electric motor.
IE its just not a good idea. but that does not mean it won't work.
