Old 01-28-2011, 06:51 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Big Dave View Post
I’m looking for a little brainstorming for two projects.
I’m not going through this exercise and throw it all away through an inefficient slushbox.
So why go through this exercize and throw it all away by starting out with an inefficient, heavy vehicle for such a small payload
Body-on-frame certainly has some advantages, but you can't overlook the disadvantages : sheer bulk and weight, and less than ideal tyre options.
Driver plus 50 lb groceries = payload.
How about a station wagon rather than a truck ?
Or a (smallish) MPV.
Especially given the speeds you want to travel at, aerodynamics are going to have a serious impact.
You could aerohead a truck, but you could also basjoos a station wagon or MPV if you want to go all the way on aerodynamics.
Both wagon and MPV should allow enough room and load capacity for a substantial battery pack for the (long !) EV-range.
A lighter vehicle will allow for a lighter motor.
My 2 cents of brain
