Did you see the range required? This vehicle will need a very big battery to go that far. I don't sweat the weight too much as my terrain is as flat as a pool table.
I do not have the coachbuilding resources of a major corporation. Body-on-frame is easy to modify.
I fully intend to aerohead/basjoos the vehicle as much as possible.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
