Old 01-28-2011, 07:52 PM   #29 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vanquizor View Post
Not sold on the wheel covers... our 4 tire change was under a minute last time we practiced, it would be tough to convince me the aero gained would make up for the time it took to peel off the covers and re-install them.
You could make some holes in the wheelhubs where the bolts are.
A hinge could make the wheelskirt swing aside / up.
I've been eyeballing the back of the car, and I wonder what gains there would be going to a fastback. I thought I read somewhere that if you end up with an angle between 15 and 30 degrees it was worse for drag then cutting a steeper angle and letting the air seperate.
Yes, drag increases as the angle of the rear window increases, then drops again when the angle is steep enough (hence the Kammback).
You'll find more aerodynamic illustrations here :
Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - Piwoslaw's Album: Aero drawings
The Following User Says Thank You to euromodder For This Useful Post:
Mira (05-01-2013)
