How do you keep the skirt away from the tire when the tires are straight on ?
The material that you are using is flexible and I can't understand how that it is not just being pulled onto the tire.
Is there any bracing used ?
I might have asked this already, but what is between the tire and the shower liner to keep it from melting the liner ? ( when the tire makes contact )
Thanks. Really clever design !
