Originally Posted by roosterk0031
...with 1/4 the distance commutes but got double the tire life. I think short trips don't heat up the tire and they last a lot longer, my commute got them up to heat, soft and sticky (using sport tourning tires) and wearing faster per mile.
This is an interesting question, how much tire temperature affects longevity.
If it's a real factor, and cold tires really don't wear too much, it's pretty much conserved on my late commutes, when temps were around zero Celsius, and when I touched rear tire after arrival, it was colder than my hand.
On more thing I suspect: riding 2-up wears tires faster too, and I did it for several thousand kms this year, a few hundred kms at once (nothing like a short commute). On the other hand, I'm quite lightweight (by American standards, in Japan I wouldn't be small
), which is a relief for them when I ride alone.
And different tires are well, different. I use Metzeler Z6, at least so far. Next time I may try another type (a Heidenau my mechanic recommended for all-weather riding, probably more sticky and faster wearing, and I don't know about its effect on fuel efficiency.) What tires are on your bike?
