[QUOTE=MPaulHolmes;215665]I'm almost done with a 1000amp power section, control section, and driver board for the mosfet version. It's non-SR, since I just found some much improved freewheel diodes that are 150amps per device instead of the 60amp ones I've been using. QUOTE]
Paul,
your development of the 1000amp non-SR design is the most exciting news I have heard since back on post #600 where you got the original version running in your car. I believe this addresses the ONLY real short-coming with your 500amp version, at least from the open-source, KISS approach you have taken.
Will you be releasing the design details on this new version: schematics, layout, BOM, etc? Possibly another kit for your store?
-Wes
