Old 01-30-2011, 06:06 PM   #1 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
What is the lowest power x86 compatible desktop PC you can build?
My parents more and more can't run their PC at craft shows because of needing electricity or a generator.
We have run batteries several times but many places have a cow even though the batteries are unspillable sealed Greensavers.
I DO NOT WANT A LAPTOP and will do that as a last resort only.
Requirements.
1. Desktop or tower PC, preferably a case large enough that fits standard components when I need them and is durable
2. X86 compatible, our proprietary business software runs under Windows 9x only and is only semi functional under XP
3. Did I say low power? I would like it to run at as low of power as possible, if I could buy one that used a single watt and was still something I could buy and build easily I would buy it.
4. I use a monitor to display our work to customers, size is not important (13"+) but it should be separate from the computer so I can place it near the customers without my keyboard being in the aisle and obviously it must use very little power, I could do with B&W but color is prefered, since we are usually in a tent under full sun a reflective model might work and I would definately consider ANTIQUE monitors if they use very little power and have a Windows 9x interface card.
5. Only needs to be Equivalent to a pentium 133mhz or better, better is nice lower power is better. I need a minimum of 32mb but 256mb is obviously much better. I need VGA or better, better is prefered, I need Parallel and would like USB.
6. Age, I could care less, in fact if I could buy a used low power system that would be even better.
My printer I am somewhat stuck with as I can't really find any that are much more efficient and still run as a laser.
Currently my system when putting around but not printing uses 100-130watts for a 19" monitor, tower computer and idling printer.
I would very much like to reduce this, I can only run 3 days on battery power max at this rate with about 3 dozen surges to 500watt for 15 seconds. (not really 500watt constant over the 15sec.)
If I could reduce the rate my 4 battery pack could be reduced to 2 batteries or possibly 1 battery.
I also would consider a system like this a nice chance for me to have an excuse to build a PC system again and a Nice intro to the possibility of running on solar
Are there any complete PC systems that only draw a couple watts in the desktop form factor and are x86 compatble?
The Intel ATOM as far as I can tell draws more power as a system then my antique crap box but it is faster. (AKA 80watts for an ATOM is not unheard of)
Thank You
Ryan May
