Old 02-01-2011, 11:50 AM   #25 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
First test piece tried out with bad luck. As you can see from the pictures i tried to meld the abs outside and it was -3 celsius. With that fire heater I was only able to melt about 400mm soft enough. So when I placed that plastic sheet to my vacuum forming table I did not get no suction because the abs did not touch the table. Also the "tool" was sucted inside with regular 1400 watt Volta vacuum cleaner.
DIY vacuum forming heater.JPG - Windows Live
Next stage is to build proper heating system that I will get that full abs sheet soft and try again...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
