Old 02-01-2011, 01:04 PM   #7 (permalink)
Frank Lee
Depends on how much you cut. Sure, taking away from available ride travel will compromise ride quality. The question is how far do you want to go? What's the difference between cutting a spring and getting a shorter one? Answer: none.
One way to lower without affecting ride quality is to use dropped spindles. I suspect they aren't available for that Jeep.
