Old 02-01-2011, 06:56 PM   #35 (permalink)
Vanquizor
Assuming I'm going with a 4 section flat bottom, section 1 being the splitter to front rad support, section 2 the bottom of the engine bay, section 3 the main underbody, and section 4 the diffuser. what kind of angles should I be shooting for with respect to the ground?
I'd kinda pictured the first 3 as parallel to ground and the 4th at about a 5 drgree angle, but not set on that. If I pitched the whole underside at 2 or 3 degrees it would allow me to get a gentler slope on the rear fastback...
