If you have a set of torches, and are good with them, you can heat the coil, and it will compress. Be careful
![EEK!](/forum/images/smilies/eek.gif)
If you do this wrong you will create a coil of scrap steel.
Another thought. Some manufacturers used different spring rates for different engines. There may be a stock spring available with a slightly different ap.
