Standard narrowband O2 can detect wider than 14-15 AFR . while that range is were it is most accurate I have seen it able to output values wider than that graph (something like low-mid 13's for 0.9v and probably same on high end,close to around 16 AFR but i never checked that end )
As above poster running lean has many side affects , I wouldn't do it alone .
