Old 02-02-2011, 01:33 PM   #31 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Series of recent events:
  • I wrecked Gerald Ford. (My F150). He's totaled.
  • I filled out my taxes, and came to the realization that for the most part, I don't need a truck, as long as I have a trailer.
  • I passed my CDL A permit test.
  • I decided to get back on this project so we (my wife and I) have a second car, and so she can learn to drive manual transmission vehicles.
Work list:
  • Started playing with the car. Same dead battery as before. Ended up buying a new battery from AutoZone for $110 or so.
  • Got the battery in the next day, cranked seemingly endlessly before it finally popped off. Wouldn't run to save a life.
  • Removed pump inlet line from filter - placed in can of trans fluid (used). Ran perfectly almost instantly.
  • Assumed fuel in tank was bad. Several hours of messing around, decided that pump was sucking air.
  • Bypassed water separator (burn the water... just makes it run rough for a minute) and inspected (plastic) fuel lines for holes or pressure leaks.
  • Removed fuel sending unit and inserted line directly into fuel. Siphoned up to filter. Ran engine - perfect.
  • Cleaned, inspected sending unit. Found pinhole in pickup line.
  • Melted plastic around line, covered hole with hot glue.
  • Reinstalled sending unit today - perfect runner.
Left to do -
  • Buy, service, install, etc. Glow plugs.
  • Tie down battery
  • Brakes - Inspect, service, replace.
  • Title/Registration (will be taken care of by end of week.)
Long term -
  • Shave door handles/rust repair
  • Rhino Lining (or similar) under chassis and on door sills/rockers.
  • Brake system upgrade - 4 wheel disc brakes
  • Of course - Lightening chassis
  • IP mods for FE/Torque, Intake/exhaust mods.
  • possible WVO conversion or BD @Home station.
