Old 02-02-2011, 04:12 PM   #75 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by ai_vin View Post
The Probe V was the last of a series so I imagine they used the same trick they used in the Probe IV: The radiator and air conditioning compressor were located at the rear in order to eliminate a high drag radiator opening in the front (or nose).
Why isn't that done more often?
It is done, but only in mid- or rear-engined vehicles. Most passenger cars are front engined, since that is the most functional solution as far as passenger/cargo space goes. Putting the radiator(s) in the back would require a long length of plumbing (weight) and lots of coolant to fill it (more weight). The gains in simplicity and weight savings outweigh (pun intended) the extra aero drag.
