Old 02-02-2011, 06:41 PM   #9 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by roflwaffle View Post
It looks like the sulfation of the lead plates makes the sulfuric acid more basic so adding epsom salt, water, and energy via heat/charging provides more sulfuric acid by stripping the Mg from the epsom salt.
Not exactly, what you say does gradually happen but it is much more complex than that.
Sulphation is non-conductive as is depleted acid (water) epsom salts conduct very well and pass through and into the sulphation allowing the plates to charge (which does cause heat which helps to break up some sulphation), they give up their Sulphur to the battery plate and break away sulphur in the sulphation (depending on if you are charging or discharging)
The magnesium also interacts with "rusted" lead.
Lots of things happen when you add epsom salts and being able to charge is one side effect.
Worth a try as the stuff usually does work but again at a cost. EDTA is better and an EDTA wash is better yet.
Good Luck
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
Christ (02-06-2011)
