Old 02-03-2011, 03:05 AM   #29 (permalink)
George Tyler
Are you sure that the fuel is what caused the problem? Iagreed in the beginning, but thinking about it, the engine has been running, the surface temp of the cylinders and head and the temperature of the pistons is way above 100 deg C, any fuel is going to evaorate on contact and go out the exhaust? Also, the small amount of fuel in the high vacuum in the inlet will instantly evaporate?
