Old 02-03-2011, 07:14 PM   #4275 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Ya, using 330 Ohm in, 3kOhm out on the hcpl4504 make the controller turn in to a 70kW AM radio noise transmitter. hahaha. But the hcpl4506 works better. Better current transfer ratio. The schematic resistor values were never updated. One reason I like the dspic is that it has programmable dead time and the pwm pins can run in complementary mode (up to 8 pwm channels depending on which one you use). It also has some protection details for complementary output mode on the boundary issues, like when one is of less pwm duty than the dead time and stuff like that.
kits and boards
