I've seen some people post about mounting the pizza pan with no drilled holes (for zipties, etc). How about some good ol' JB Weld?
Get some eyebolts or thick washers (or similar), bond them to the inside of the hubcap, then run the ziptie through the eyebolt hole to attach it to the wheel.
It would not be easy to take off for tire changing unless you mounted the eyebolt right at the edge of the pizza pan and could pull it out far enough to cut the zipties with a knife. But for some (myself included), the benefit in appearance would be worth it.
Any downsides I've not considered? It would add a couple bucks to the project I suppose....
