Originally Posted by mnmarcus
Or attach a string to a pencil and draw an arc that extends a little past the middle. Spin the pan about 180 and draw another arc. Connecting the 2 points where the arc intersect will make a line exacly through the center. Repeat at some other angle and the lines will intersect exactly at the midpoint of the circle. I love the fact that you don't have to measure anything at all but it works great...
I am lazy and use electric mauser to draw the cirle. You get the center point straight from the drawing. Other solution is to use mauser if you already have ready pizza pan. Just measure the diameter and put value of the radius to mauser. make three arches and you have your center point. Works already with two but three makes it more accurate.
I got my electric 300mm mauser for 25€ on sale
